Importing graph from Mathcad to Labview
Hi everyone. I'm developing an application acquiring the data in Labview, processing it in Mathcad and sendind the resultas back to LabView. The problem is that although I've successfully done all the calculations, I haven't been able to display in my front panel the graph mathcad generates. Does anybody know how to import it?
Thanks.
(3,611 Views)
Hi Ali!
What version of mathcad are you using?
There are some Vi's you can use for interaction between mathcad and labview that i do not know if you already have but that may help you. The link where you can download this VI's is this:
http://zone.ni.com/devzone/cda/epd/p/id/4348
I hope this helps you and you can import the data as you need, have a great day! 🙂
Oswald Branford
(3,590 Views)
Hi, thanks for the tip. Yes, I'm already using the VI's you talk about, but they're designed to write and read data, not graphs. I think I'll have to use a waveform graph to get what I need.
Cheers,
Ali
(3,570 Views)
