Importing VHDL to IP Node
I am trying to import some VHDL code from Xlinx into LabVIEW but am getting the following error..
*                          HDL Compilation                              *
Compiling vhdl file "C:/NIFPGA/iptemp/ipin0EB4CDC0445C609326F127B586C4B175/encode_8b10b_rtl.vhd" in Library work.
ERROR:HDLParsers:3317 - "C:/NIFPGA/iptemp/ipin0EB4CDC0445C609326F127B586C4B175/encode_8b10b_rtl.vhd" Line 66.  Library encode_8b10b cannot be found.
ERROR:HDLParsers:3013 - "C:/NIFPGA/iptemp/ipin0EB4CDC0445C609326F127B586C4B175/encode_8b10b_rtl.vhd" Line 67. Library encode_8b10b is not declared.
WARNING:HDLParsers:3481 - Library work has no units. Did not save reference file "xst/work/hdllib.ref" for it.
I've spent quite a lot of time trying to understand the problem but my VHDL experience is limited and I've not been able to find any suggestions so far. As I understand it there's a problem with the  encode library although its defined as a package within the VHD files I upload. I've attached the .vhd source files, so if anyone can advise me how to convert this into the labVIEW IP node that'd be great.
Many thanks
(3,529 Views)
I worked with F7ash to resolve this issue. As mentioned in the previous post, the component level import failed because it could not find the encode_8b10b library (referenced in the top-level .vdh file).
From the encode_8b10b_top.vhd code...
LIBRARY encode_8b10b;
USE encode_8b10b.encode_8b10b_pkg.ALL;
We used the ise.exe (found here... C:\NIFPGA\programs\Xilinx12_4\ISE\bin\nt) to create a consolidated project. This was then imported into LabVIEW without error.
Feel free to add any additional info you feel relevant F7ash. Many thanks!
Rich Roberts
Senior Marketing Engineer, National Instruments
Connect on LinkedIn: https://www.linkedin.com/in/richard-roberts-4176a27b/
(3,500 Views)
