Importing Labview DLL in TCL
Hi, I am building an ATE system that requires some integration between TCL scripting and Labview VI functions. What I need help with is getting a vi that has been exported as a shared library (dll) to load properly in TCL. Initially, I got an error in TCL because I didn't have a pkg_init file. I am a little fuzzy on the structure of how this file is used and what all needs to be in it. I built one which is PkgInit.c, and TCL recognizes it, but still can't load the Pkg.dll because it states it is missing a dependant library. Anybody know what I am asking? I believe that I am missing something in this init file.
Any bilinguals out there know much about integrating LabVIEW/TCL?
For backgound roughly on my delimma is that I am using Labview in a very large ATE setup. I have a particular interface that uses TCL, but it loads a package that takes about 12 seconds, then I run some commands in LV and go back to TCL and it takes another 12 seconds. The going back and forth creates an unreasonable delay. The LV commands I initiate between the TCL commands are very simple GPIB commands that I'd like to just put in TCL so I can run one long script, with one package load, then back to LV.
Any help would be greatly appreciated.
(3,117 Views)
You might want to check to see if the dependent libraries it's complaining about are LabVIEW libraries, such as the advanced analysis library. If one of your VIs is using a function from that library when you compile your application into a DLL you will need to lvanlys.dll library as well. As for moving the GPIB call into TCL you might want to take a look at this:
GPIB-Tcl
Note: I have no experience with this - I just did a search on these discussion forums and then a quick google search when a link in one of the messages was obsolete.
(3,094 Views)
