Import shared library
Hallo,
I'm trying to import a .dll with the wizard in LabVIEW 8.5.
I'm doing the following:
1. Selecting the .dll and the according .h file. Click "Next"
2. Don't use any includes and defines. Click "Next"
3. "parsing header file..." appears for 2 sec. It dissapears and nothing
happens. No output, no action, no error messages.
Any ideas?
Oli
(3,488 Views)
What kind of DLL is it?
(3,472 Views)
Hi Olivier,
This is actually a known issue that occurs when the Report Generation Toolkit is installed.  You can find additional information here.  This has been fixed as of LV 8.6.
Message Edited by David_B on 10-07-2008 09:24 PM
David_B
(3,418 Views)
I'm having the same problem and I have uninstalled the Report Generation Toolkit.
The problem you refer to is different in that the known issue is the wizard hanging with the Next button is greyed out.
What I get & what is reported in this thread is the wizard pops up the message saying it is doing something, then closes 2 seconds later having done nothing.
The Next button is available, but if clicked, all that does is repeat the same 2 second popup!
Upgrading from 8.5.1 to 8.6 is not an option.
Is there a workaround?
Cheers
Duncan
(3,272 Views)
