07-20-2010 04:32 PM
Is there any way to import a the message table resource from a DLL (or, specifically, an OCX file) into LabView such that the error dialogs will properly report error codes returned by DLL calls?
Thanks!
Solved! Go to Solution.
07-20-2010 05:11 PM
The only thing you can do with DLLs is call functions, and with the ActiveX interface you can only access the exposed methods and properties. Perhaps you can create a function to return the error string based on the error code?
07-20-2010 05:21 PM
Yup, that was the fallback plan. I noticed that there's a provision for user-defined codes and messages and would have generated a message .txt file, but the DLL message codes don't fit in the LabView's user code ranges. So fn call it is.
