Import images and rearrange
I want to import a set of lets say 3 images. Among this 2 are of importaance and the third is not. The importance is determined based on the which image is the darkest. And the rest two images should be named as Image-1 and Image-2.
How can I achieve this ?
Abhilash S Nair
Research Assistant @ Photonic Devices and Systems lab
[ LabView professional Development System - Version 11.0 - 32-bit ]
LabView Gear:
1. NI PXI-7951R & NI 5761
2. The Imaging Source USB 3.0 monochrome camera with trigger : DMK 23UM021
OPERATING SYSTEM - [ MS windows 7 Home Premium 64-bit SP-1 ]
CPU - [Intel Core i7-2600 CPU @ 3.40Ghz ]
MEMORY - [ 16.0 GB RAM ]
GPU - [ NVIDIA GeForce GT 530 ]
Message 1 of 9
(3,729 Views)
How about comparing overall pixel intesities of the image.
Message 2 of 9
(3,722 Views)
Hello Ankit,
Yes I am new to LabVIEW, please explain in detail how can I achieve that. I want to do it myself.
Abhilash S Nair
LabView Gear:
Message 3 of 9
(3,720 Views)
Try this link: Overall Image Intensity
or you can also convert you images in to an array compare the images.
Message 4 of 9
(3,714 Views)
Thank you , will try and update if I was able to do it.
Abhilash S Nair
LabView Gear:
Message 5 of 9
(3,710 Views)
Do you have a Vision license from Labview. If so it's exteremly easy and I can set up a quick VI for you that performs this task. but the effor is nulled if you don't have the Vision license.
Dan,
Message 6 of 9
(3,692 Views)
Yes I do have a liscenced version for VISION.
Abhilash S Nair
LabView Gear:
Message 7 of 9
(3,679 Views)
I have developed a VI that says which image is the lowes intensity among the 3 images in a given folder. How can I automatically delete that image from the folder and rename the other two as Image 1 and Image 2 ?
Abhilash S Nair
LabView Gear:
Message 8 of 9
(3,677 Views)
Sorry,
I 'm short on time so I quickly put this together.
Feel free to add the front Panel object as you see fit.
If your images are in a restricted folder you would have to run labview as an admin since you are deleting files.
Let me know if you have any other questions.
Good luck
Message 9 of 9
(3,666 Views)
