Import excel 2003 and 2007 files containing numbers and text into LabVIEW
Hi
I am trying to import som *.xls (2003) and *.xlsx (2007) files containing numbers and text into LabVIEW but I cannot get it to work. First column with text and the second with numbers.
Can anyone help me with a small example? Is there an easy way?
FYI
I have access to all packages and addons for LabVIEW through my work (University)
Best regards
Simon
Message Edited by SCMAJA on 07-10-2009 11:35 AM
LabVIEW 8.6 / 2009 / 2010
Vision Development Module 8.6 / 2009 / 2010
VBAI 3.6 / 2010
(3,368 Views)
save the Xls file in Tab-delimiter format. then use "read from spredsheet" to read the file.
Message Edited by Ranji on 07-10-2009 04:36 AM
(3,359 Views)
I would very much like to have just one file for each dataset for the ease of the user, therefore not wanting to save any additional files.
Message Edited by SCMAJA on 07-10-2009 11:39 AM
VBAI 3.6 / 2010
(3,353 Views)
Accepted by topic author Little_Helper
There is an example using the Report Generation toolkit.
http://decibel.ni.com/content/docs/DOC-4965
It should give you a place to start.
Hope this helps.
Now Using LabVIEW 2019SP1 and TestStand 2019
(3,333 Views)
Hi GovBob
That is exactly what I was looking for, an easy way to import *.xls and *.xlsx files directly into LabVIEW, good example 🙂
Thank you GovBob
VBAI 3.6 / 2010
(3,306 Views)
