Import a tdms file to database
Dear all
I receive a TDMS file via labview form another PC and I need to put the data into a database which I have already built. Is it possible to do that by labview?
(3,871 Views)
Hello yangs,
LabVIEW has full TDMS manipulation capabilities (reading, writing, setting properties, etc.) You can find the corresponding functions on the Programming -> File I/O -> TDM Streaming palette. If you can access your database with LabVIEW, you will be able to import the TDMS data.
Daniel
Dániel Fülöp
Field Application Engineer (CLA, CTA)
(3,861 Views)
Hi yangs,
you might also take a look at
LabVIEW DataFinder Toolkit
and
DataFinder Server Edition
which are out-of-the-box indexes (databases) for TDMS files.
(3,853 Views)
Accepted by topic author yangs
i have found some ways to get this done.simply read group first and then chanels..
(3,819 Views)
hii
I would like to import my real EEG database into the labview for analysis them .how can I do it ? I mean how we can import database into the labview?
thanks
(3,782 Views)
