Import Python. Datatype List[int]
Hi
I have imported several .py files.
Now I have a Python datatype called list[int] that I don't know how to interpret.
Is there an datatype in LabVIEW that can be used for List[int]?
(2,101 Views)
Hi Kim,
From what I learned about Python you could use an array of integer (I32?) in LabVIEW…
(2,058 Views)
An integer array should work. As an example, I can write the following function in python:
def incrementList(listnIn):
    return list(item + 1 for item in listnIn)
In LabVIEW I can call the incrementList function using the Python Node with an I32 array as the return type and some other I32 array as the first input. I32 was just what I chose but you should be able to substitute that for any integer representation.
(2,046 Views)
Thanks for both of yours replies Matt and Gerd. It works now
(2,021 Views)
