Import Library Error two functions with same name on different namespaces
Im trying impor a library developed by me. In this library have two functions ShowMenu. First function be inside into a class and its declared as
void __fastcall TTrayicon::ShowMenu(). The second function has declared as extern "C" __declspec(dllexport) ShowMenu(int x, int y).
When i use de assistant to import this library i select the library and its header file. But in the next step the assistant show to me the first function.
Anyone explain what's happen?
(2,879 Views)
LabVIEW doesn't do C++ DLLs, so it doesn't distinguish based on classes. That's why you have to use the extern modifier.
(2,866 Views)
I understand wich LabVIEW doesn't do C++ DLL. But only the second function have an extern modifier
(2,848 Views)
I'm not sure what kind of answer you're looking for. LabVIEW's Import Library wizard does not always properly handle accessing functions in standard C++ DLLs. See this for more info.
(2,836 Views)
