Import & Export Strings method
I have a multilanguage application. I have used export & import strings methods. I have one .txt file for each language but when I modify something in my vi I must export all again and then modify the tags again for each language file... Is there a way that I can modify my vi and I don't have to export all again?
ToNi.
(3,169 Views)
As far as i know you need to export strings again only if you have made any changes on front panel.
exported file is nothing but a xml file so that you can manually edit it instead of exporting everything again (helpfule if you have done very small changes on front panel)
Tushar Jambhekar
tushar@jambhekar.com
Jambhekar Automation Solutions
LabVIEW Consultancy, LabVIEW Training
Rent a LabVIEW Developer, My Blog
(3,111 Views)
