Import Data
i would like to import the results from the following program to a text file..text file should have the time in one column and Y values in the other column. how do i go about it coz i cant seem to wire the get date time into an array..plz help
(3,632 Views)
Hello
See the example.
Software developer
www.mcm-electronics.com
PORTUGAL
(3,612 Views)
could you plz put it for labview 8.0
(3,586 Views)
Hi KenLabView,
here it is.
Mike
(3,583 Views)
how do i set the default file name and path so that i dont have to select it everytime i run the program
(3,541 Views)
Right click on the file-path control then select data operations -> Make Current Value default.
(3,537 Views)
Or right click on the control and select Change to Constant.
(3,533 Views)
