Import CVI Instrument driver with void pointer
I would like to use a CVI instrument driver that contains void pointers as parameters in LabVIEW. There are additional parameters which declare the kind of data where the void pointer points to.
If I try to import this driver to LabVIEW I get warnings that the void pointer paarameters are converted to I32 since LabVIEW do not have the void pointer.
Does anybody know if it is possible to import a CVI function with void pointers that will work properly in LabVIEW? How do I have to handle this converted void pointer?
Thnaks,
erik.
(2,729 Views)
Erik,
you may have a look at this discussion forum thread.
Jochen Klier
National Instruments Germany
(2,715 Views)
