Implementing PLL in FPGA LabVIEW
I want to implement PLL in FPGA by refering to the example(the file is attached).
I've modified the example, so that it can work in single phase PLL (the file is attached).
However, it is not working.
To be honest, I'm new in LabVIEW, so just have very little knowledge about this software.
(3,255 Views)
Could you provide some more information?
1.) What do you mean by it is not working? Possibly some more information, error codes, screen shots etc.
2.) At what point is it not working?
4.) Did the example work?
        If the example did work, it might be worth going back to that and seeing if it will run at each stage of development. You will then be able to pin point the change that gave you the error.
3.) What hardware are you using?
Good Luck with LabVIEW!
James O'Neill - Applications Engineering - National Instruments
(3,210 Views)
