Implement json web token JWT with labview
Hello dor-s: Looks like a solution to this was voted for milan.
So I am just adding a further tip on how to implement web token authentication and authorization after you get a returned web token after login.
I have attached two things:
1. -- Pictures of VI block diagram and Front panel showing how a login POST can produce web token for authentication.
    -- Same VI shows how web token is submitted as a header under authorization. The VI has comments that described hwt each VI does.
2. Next I have attached a VI lib for the labVIEW code shown under 1. (above)
Happy wiring
Anthony Lukindo
Message 11 of 11
(1,025 Views)
