Implement Level Translator in Labview
Hi
 I need a design of  level translator in LabVIEW such was the voltage level 1.8V to 5V vice versa
(3,253 Views)
I don't understand you question, can you please explain with an example?
(3,250 Views)
Hi Diana,
LabVIEW is a programming language, so your request translates to a simple scaling function.
When you need real hardware you need to use a soldering iron and a PCB…
(3,235 Views)
Accepted by topic author Diana_Mary
I will answer the question you asked.  Attached is a VI that will take a input range which at the moment is 0 to 1.8 and it will scale that to a new range which at the moment is 0 to 5.  This could be used with an analog input, and an analog output to create what you want.
(3,207 Views)
 Thank you so much
(3,170 Views)
