Immediate Software Trigger to Tektronix AFG3000 Function Generator
I use Tektronix AFG3052 function generator sending pulses, and monitor them on a scope. It worked correctly configuring waveforms and setting edges, but can't issue an immediate software trigger.
Attached is a modified VI, based on example from the AFG3000 library, and FG screen capture. After running the VI, FG displays message "Waiting for Trigger (Ch1)". If I press "Manual" button in Trigger section, the scope captures the burst. I need a software command to start immediate burst without manual operation. Appreciate your inputs on how to implement this.
(4,206 Views)
Using that option from Gregory or you can use the other option of:
Help the Community (and future reviewers) by marking posts as follows:
If it helped - KUDOS
If it answers the issue - SOLUTION
(4,168 Views)
gregoryj and Minions, thank you very much for your inputs.
I tried more and realized the Enable Burst.vi did act as an immediate trigger. There were confusions earlier when I placed the vi at the beginning of my sequence, and it triggered periodically.
(4,122 Views)
