09-19-2012 07:40 AM
I am looking for a possibility to imitate the bevhavior of a boolean switch with an event structure. To be more precise, I want a boolean value to change each time I click on the front panel indicator and then remain constant until I click again. I have not worked with shift registers in a while loop yet, but could this be a way to find a solution?
09-19-2012 07:48 AM
09-19-2012 10:03 AM
Okay, I figured it out, BUT I still have a problem. Before I first trigger a mouse event on the front panel indicator, I already need the case structure to be executed once. Therefore I assume that I need some kind of default value, but since the event structure does not create any output at first, I have no idea how to do that.
09-19-2012 10:22 AM
One method to get this type of behavior is to use the timeout event for initialization
09-19-2012 10:26 AM
Are you talking about the shift register you just created? You can while in a default value on the left shift register ndoe. It is wired outside of the loop.
