Imaq buffer limitation
Hi
I'm having problems with the imaq sequence.vi. It seems that the number of
buffer is limited to 50. It gives a physical memory limitation. I doubled
the memory on my HP PII 450MHz to 256 and I still get the error message.
This does seem to be a physical memory problem. I am using a pci 1408, while
I'm still waiting for my pci 1411.
Anybody has experience with the use of hign numbers of buffers?
Thanx
(5,179 Views)
For those following...
You need to specify the maximum number of image buffers in the imaq utility
tools.
Thanks for the prompt response from the guys at Natinst.
Champlain Landry wrote in message
news:7yra3.10695$U4.551895@carnaval.risq.qc.ca...
> Hi
while
> Thanx
(5,179 Views)
