Imaq Get points on line
I am trying to interpolate my graph of measured x- and y-values! Therefore I am using the ImaqGetPointsOnLine.vi which gives me a big amount of value-pairs between twi measured points! The Problem I have is that my measured values are both floats and the VI just gives back integer! Can I manipulate this VI in a certain way so that it works also with floats?
I am using LV7.1 and Vision 7...
Thank you
(2,531 Views)
I have been doing some research into this, and it doesn't appear that the IMAQ Get Points On Line.vi function can deal with anything other than integer inputs, and therefore won't give anything other than integer outputs.
Daniel - Applications Engineer, NI UK
(2,514 Views)
