Image transfer between LabVIEW and VBAI through network shared variables
Hi. The project I am working on involves LabVIEW 2020 and VBAI 2020. I am acquiring images from a line scan camera in Labview VI. The images are then transferred to Vision Builder through shared network variables. When I run the VI, there is no problem - transferring image is also working.
I have to build the executable application( build Specifications -> New -> Application (.exe) . I was able to build the VI and the library without errors and it is working in the background without unexpected problem. When I run the exe file, I am getting the error which has been attached. The exe file is working but images are not transferring. Other type of variables are transferred but I have problem with image type variables.Do you have any idea how to solve this problem?
In vision builder part I am reading images by using both  "Set Variable" and "Select Image" steps. Set variable step says "Missing Measurement", Select image throws error "IMAQ Copy".
(1,362 Views)
If you have not already seen this, there is a procedure to deploy shared variables in an executable.
Deploying Network Shared Variables from a Compiled Executable
Patrick Allen: FunctionalityUnlimited.ca
(1,336 Views)
I have seen it before, I had already applied these configurations when I created the variables.
(1,325 Views)
