Image processing
Hello friends,
I have a robot which I have made functional completely through labview. My next goal is to drive the robot using an image file. Like I will have a image file which will have simple lines and curves which will tell the robot where to go. My problem is I am not able to extract these parameters from an image ( I am new to labview image processing). I want to extract parameters such as lines, curves and also the distance between the two end point of the lines. So how will I be able to extract these from the image file using labview ? The image will be black and white only. I am not sure as to which functions I should be using here. IF you want any other information, I can provide you that.
Thanks 🙂
(3,053 Views)
Post your image. If not much of complication in the images, you may try to use pattern matching function.
(3,036 Views)
hey. thanks for the reply.. am  just looking at a picture (jpeg image) where I will just draw straight lines and curves using black ink. The robot has to travel accordingly. So I just wanna extract the lines and curves of the image. Since I will not know about the pattern that the user might give, I am not sure if pattern matching will be a good idea. Thanks a lot for the reply again.
(3,002 Views)
