Image development from intensity values in X-Y plane
       How can I plot an image from set of intensity values stored in data base and plot this intensity values on X-Y plane with varies (x,y) values.intensity values varies from (x,y) values
Message 1 of 8
(4,152 Views)
Hi manojkp,
ever tried to use an IntensityGraph?
Message 2 of 8
(4,150 Views)
Use IMAQ Array to Image.
uday
Message 3 of 8
(4,140 Views)
hi, Can you sent example vi
Message 4 of 8
(4,110 Views)
Hi manojk,
here an example with an intensity graph:
Setting a random value at random XY coordinates...
Message 6 of 8
(4,101 Views)
Is there any problem while using IMAQ Array to image Vi in the case of gray scale.
Thanks and regards
Manoj
Message 7 of 8
(4,086 Views)
Hi manoj,
No problem at all, You need to select grayscale in enum/ring connected to IMAQ create, Image Type terminal and it should work.
uday
Message 8 of 8
(4,080 Views)
