Image.cpp error, line 11067
I am getting the following problem while opening the VI.
The VI does not open and gives the following error :
LabVIEW version 6.1
I have tried using LabView version 7.0, the problem persists but with a different line number.
Image.cpp error, line 12443
LabVIEW version 7.0.
However, all other VIs are opening. The operating system is Windows 2000 and I am not connecting with any hardware device. I have tried changing the video accelerator settings and display settings as mentioned on the NI site but in vain.
(3,372 Views)
Which version of LabVIEW was the VI last opened and saved in?
Here are some general suggestions for you to try to recover this VI:
LabVIEW Internal Errors (Failure in XXX.c / XXX.cpp at line YYY)
If after these you still cannot open the VI, please send a support request email to ni.com/ask with the VI.
Zvezdana S.
(3,372 Views)
i have saved the VI last in LabVIEW 6.1 and here it gave the error
Failure :"image.cpp", line 11067
i have tried all the general suggestins but in vain.
This problem came when i was using the property node functins in the block diagram.
i am sending you the VI, attached with this comment.
(3,372 Views)
Unfortunately, I was not able to recover your VI. I've sent a report to NI R&D to investigate it and prevent this happening in the future. I am not sure if they'll be able to open the VI either.
Do you have a backup copy of the VI that you can use?
Zvezdana S.
(3,372 Views)
