Image Processing on sbRIO-9651 SOM
I am using SOM sbrio-9651 development kit, i've interfaced an AMLCD with it. I've implemented an image rotation algorithm on RT, after processing I am sending this data to LCD via FPGA using DMA FIFO. Image rotation is being displayed on LCD but issue here is that I am not getting the desired frame rate per second (25FPS/40ms) as RT is taking much time for processing. Currently image processing time is around 250-270ms.
For Image rotation, I have developed my code in C and then using it in RT labview via Call Library Node.
If I develop some algorithm in Labview RT vi it takes approx... 600-700ms, (I also used image rotation example provided in LABVIEW Example) that’s why I am using my C code for image rotation.
I tried to transfer my original image data on FPGA for processing but problem here is image size (1MB) and I can’t transfer it to FPGA BRAM.
Is there any way I can increase my frame rate per second? Also can I use NI-IMAQ for SOM sbrio-9651, will it be a good practice?
Any suggestion or example code is more than welcome?
Message 1 of 1
(2,357 Views)
