Image Out problem
the Image out seems show the Thresholded picture ...
I want them to show How their Pattern Matched the object and also the Centroid of the object instead
any solution for this?
(3,680 Views)
can u save in Labview 7.1 version and send me....i have this version only
(3,666 Views)
Why do you want them saved in LV 7.1?  Are you trying to help answer the question?
They are saved in LV8.2.1 which means the original poster would have to save them back by 2 versions (they would need LV8.0 to do that).  Considering they are obviously a newer user to the forums (first logging in in Dec 2009), they probably are not a long time LV user who would have version 8.0
If you only have version 7.1, you aren't going to be able to help very many people on the forums.
By the way, please type your replies using full English words  "u"="you".  This is a professional forum and not a bunch of teenagers text messaging each other on cell phones.
Message Edited by Ravens Fan on 01-09-2010 10:09 PM
(3,648 Views)
Hi NuMetal,
I'm a little confused as to what you're asking for here. The Pattern Match will export the positions of the matches, but won't display that.... You want the match position drawn for you? Is that what you're looking for? Please clarify.
Jeff | LabVIEW Software Engineer
(3,596 Views)
The Pattern Match will export the positions of the matches, but won't display that.... <<
anyway to make it possible to display how
The Pattern Match?
(3,593 Views)
Hi NuMetal,
No, I don't believe there is. It does give you the bounding box, angle, etc. of the match, so you can extract the necessary data and draw your own ROI from there.
I have filed a suggestion on your behalf on this question.
(3,559 Views)
