Image JPG - Get Comment
Hello
I would like to get the comment from a jpg image. I can view it with the program IfranView. Is it possible to get this string with LabView?
(2,769 Views)
Hi LN,
I see two options:
  1. Use an external tool to strip the EXIF comment tag and read the output of that tool with LabVIEW.
  2. Create your own VI to read that EXIF tag from your JPG files…
(2,762 Views)
Accepted by topic author LN86
There have been discussions about this before..
https://forums.ni.com/t5/LabVIEW/Editing-Adding-EXIF-Data/td-p/937042
https://forums.ni.com/t5/LabVIEW/Has-anyone-used-LabVIEW-to-read-Exif-information-from-an-image/m-p/...
As Gerd pointed out, there are many image processing packages that can be used with LabVIEW.  Automating ImageMagick is a good bet if you need to both read and write EXIF -
Craig
(2,718 Views)
Thank you both. I could solve it with your help! I didn't know that this is called EXIF.
(2,699 Views)
