Image Control is not supported with Vision Common Resource 2020 SP1 and LabVIEW 2022 Q3
My program uses IMAQ Image Control, and then I build an installer that includes Vision Common Resource 2020 SP1.
Use the installer on a computer with LabVIEW 2024 installed, and the program runs OK. However, when use on a computer with LabVIEW 2022 installed, the Image Control display is abnormal, only the Frame of the control can be seen, and the Image Area cannot be seen. I think this is related to the software environment, what is the root cause?
Henry
(939 Views)
In theory it could happened that earlier version of Vision don't wel integrated with newer LabVIEW like you have Vision 2020 used in LabVIEW 2022. Usually I using same or higher Vision version with older LabVIEW.
Anyway, what you can try is to select both Vision Common Resources AND Vision Run-Time.
I'm not sure if Vision Control is bundled into Common Resources, which could be just DLLs for System Folder.
Try this:
Or install Vision Run-Time separately on the target PC (after LabVIEW Run-Time), this also will work.
(917 Views)
