Image Acquisition is Flashing, Grayscale, and Wrong Resolution
I'm working on an application and need to acquire images from a USB video capture device that I have installed (Manhattan 164115 though it's listed in MAX as VC500 Video).  When I try to configure it through MAX, the video is grayscale, flashes between the image and a black screen several times per second, extends well beyond the frame, and only allows odd resolutions (the video mode it's selecting is 720x576 UYVY 25fps, though I also have options for 352x288 and 352x576, all with BGRA 8 Packed Pixel Format).  I tried capturing through the LabVIEW examples as well (after some reading I thought that the grayscale may be due to Bayer encoding), but didn't have any luck.  I'm attaching a screenshot of what I see (my instrument isn't in yet so I just have it hooked up to a TV)...
When I open the software that my capture device shipped with, everything looks fine.  I tried capturing using my built in webcam and that worked fine as well.  Any ideas on what I may be missing or what I should try?
Thanks!
(3,247 Views)
What versions of IMAQ/IMAQdx/Vision Development Module are being used on the system? Seems like the device you are using and the VC500 may have similar chipsets for A/D and USB communications. There is a detailed discussion of USB camera compatibility listed here
Please let me know if either of these documents provide a path forward. I look forward to your results.
Cheers,
Patrick Corcoran
Application Engineering Specialist | Control
(3,218 Views)
Patrick,
Thanks for the help.  I have a bit of an update...I know that the problem is that the device is being decoded as PAL though it needs to be NTSC_M.  When I switch the decoding under MAX, the device fails to initialize.  It's DirectShow compliant, so I'm not entirely sure why it's not working.  Any ideas why it wouldn't work?  Thanks!
(3,207 Views)
