Illegal Operation Issue
I am getting an "Illegal Operation", when running my VI, which states:
"LabView caused an invalid page fault in module LVS23B1.TMP at
0187:0361106f". Does anyone know what this means or is there any literature
to read which tells what this error means and how to fix it or prevent it
from occurring again?
(2,532 Views)
This indicates that one of the VIs you are using contains a CIN. The
CIN is crashing because it accessed memory that is not a valid address.
You may be able to figure out which library by turning on execution
hiliting, the light bulb, and watching where it is when the crash occurs.
Carefully check that the inputs to the CIN make sense. If the inputs
are supposed to be preallocated, make sure this is done. If everything
looks good and some tinkering with
the inputs doesn't shed some light,
then it is time to contact the maker of the CIN.
Greg McKaskle
(2,532 Views)
