If statement
Hi everyone,
I have been trying to figure this problem out for the last few hours so it would be great if someone could help me.  Basically, I am running a loop and I want to create an array that contains the iteration number when a certain event occurs.  I used the case statement but that requires me to have an output for both the True and False cases.  Is there a way to make only an if statement?
If I put the build array inside the case structure, that doesn't help because I still need an output for both the True and False cases.
Thanks so much!
Johnny
(3,219 Views)
Try a shift register initialized with an empty array. In the true case use build array to insert the element, in the false case just wire the array through.
(3,211 Views)
Accepted by topic author iamjli
Something like this
Tim
GHSP
(3,207 Views)
Ah! You guys are magnificent. Thanks so much for the help and fast responses!
-Johnny
(3,197 Views)
