If statement depending on 3 LED status
I am trying to execute an IF statement depending on 3 the status of 3 boolean values.
I have 3 array's of 10 numbers each being compared against a range of values. If the value falls within the range an boolean indicator is lit.
What i want to be able to programme is that if the 1st boolean indicator is lit for all 3 arrays then a true case structure will run. If they are not all lit then the false case will run.
I want this to happen for the 1st number in all 3 arrys, then the 2nd, 3rd etc till all 10 numbers of all 3 arrays have been compared.
Hope that makes sense and someone can help me?
I basically want IF boolean indicator is lit AND boolean indicator lit AND boolean indicator lit THEN......ELSE......
Message 1 of 8
(3,367 Views)
Is this what you're after?
Message 2 of 8
(3,354 Views)
You can use the boolean logic operators to do this - the AND operator specifically. The "compound arithmetic" function would be the best bet here - allowing you to wire all three LED status's into one VI.
Then simply wire the output of the Vi to your case statement.
-CC
[edit: Grrr, beat me to it Sebster! Smiley Wink
"If anyone needs me, I'll be in the Angry Dome!"
Message 3 of 8
(3,352 Views)
Inrange and coerce can accept arrays of ranges and values and will output an array of booleans. bool array to number and use the number to drive your case select.
"Should be" isn't "Is" -Jay
Message 4 of 8
(3,338 Views)
Check This Logic; You can replace the build array with replace array.
Regard,
Yogesh Redemptor
Yogesh Redemptor
Message 5 of 8
(3,322 Views)
I would probably do something as follows:
Message 6 of 8
(3,295 Views)
Only if your sure the logic never changes.  bool array to number allows any condition to be added to the case
Message 7 of 8
(3,280 Views)
I was pretty sure after reading this:
"... is lit for all 3 arrays then a true case structure will run. If they are not all lit then the false case will run."
Message 8 of 8
(3,271 Views)
