06-27-2011 04:34 PM
I would like to know if there is a function doing the folowing action
{ It executes [box] only if a selected [box1] was executed previously. }
OR
A function who's doing :
{ If the selected CASE structure is TRUE, it returns a TRUE. }
I tried to be as clear as possible, if it is not, ask me question and I'll try to answer.
06-27-2011 04:37 PM
In your first instance it sounds like you want a statemachine, which is usually a case structure within a while loop, with the next "state" or case, being passed from on iteration of the loop to the next through a shift register. There are examples of state machines throughout this forum.
06-27-2011 05:35 PM
Simply wire a boolean true constant (in your Boolean functions palette) to the right side of case that needs to return true.
