If I call a batch file with parameters with the system exec I get the message "Out of enviroment space"
The command Line looks like that:
command.com /C go.bat "Parameter1" "Parameter2"
go.bat starts but withe the message "out of environment space" and the parameters are not transmitted.
(2,613 Views)
Hallo,
This VI have some limitations. In the attachment you find Zip-File and when you look in the Readme.doc you will find System exec+.vi. It should go with this VI.
Greetings
PatrickB
(2,613 Views)
