Idiot's guide to creating graphs?
To do step 1:
Right click the property node then press:
Properties >> History Data
To do step 2:
Right click the property node, then press
Change to Write
*Also make sure the property node is pointing to the correct object
Right click the property node, then press:
'Link to' >> then select your chart
Cory K
Message 11 of 13
(779 Views)
thomas_p wrote:
I've put a Property Node on the block diagram (from Programming --> Application Control), outside the while loop and connected the "Error Out" terminal to the boundary of the while loop, but don't know which array block to use and where to wire that to.
Simply...
  1. right-click the chart terminal and select "create...property node...history data".
  2. right-click the history data and select "change to write?"
  3. right-click it again and "create constant".
Message 12 of 13
(774 Views)
Thanks to both for the replies - that worked great 🙂
Message 13 of 13
(749 Views)
