Identifying measured system comparing with simulated
Hello, I want to be able to match a simulated model
to a measured one.
I have started with outputting a squarewave to a rc lowpassfilter, and I am measuring the output.
In parallell I want to run the simulated responce, and if possible have the simulated responce in the same graph.
I want also be able to use Labviews built in fitting functions somehow.
Greatful for some help!
P.S. This is not a homework problem, I am not a student, I work as an instructor and I am a beginner with Labview.
(3,133 Views)
Hello
Well, I stated from your code below and modified you initial VI to do the tasks you want. If I had to develop myself this code, I would use DAQmx with VIs instead of using the express VIs because I could have more control over it. But since you started with express VIs, then I left those and tried to see if this could would work.
In attachment if my VI. Unfortunately I do not have a board on my computer (I work in R&D software.. 🙂 and I can't test it right now. Please tell if it works...
Here are some other comments:
1. First, trying to place the code in two separate while loops would make the acquisition more complex. I tried to place all the code on the same while loop, Dataflow should allow you to run both code at the same time
2. The Simulation need a Indexer to convert the waveform datatype into scalars. A collector and Resample convert back to waveform to plot on the same graph
3. I converted DDT into waveform
Please let me know if you have any questions...
Barp - Control, Simulation, RTT and HIL - National Instruments
(3,071 Views)
Hi Barp, I couldn't run it.
Attaching the screendump. It seems that you have a newer version of the simulation blocks.
(3,065 Views)
Accepted by topic author laskar01
Holy shit! It works!
I replaced the blocks in the simulation block with Labview 2010 vi's
After pushing the stop button I got the measured voltage from the rc-filter and the simulated one in the same graph!
This is big!
Thank you Barp!!!
(3,059 Views)
I am glad you were able to make it work. Actually, I have installed a patch for the Control Design and Simulation (CD&SIM) 2010. I would recommend install afterwards or just install the Service Pack 1 for the whole platform.
Glad I could help!
(3,047 Views)
