Identifying a circle in camera image
I need to identify circular object using a camera and how do I go about it?
Does the FindCircleVI works?
(4,185 Views)
I tried using that but it doesn't show how I go about it.
(4,188 Views)
Hi
You can use the Imaq Find Circle Edge 3 function to find the circle object in a image. Before going into LabVIEW develop your algorithm in NI Vision Assistant. It will be very easy to use environment, so  you can easily develop your logic.
Happy to Wire
(4,132 Views)
Hi there, thank you for replying. May I check how do I go about it if inside the vision assistant it says "IMAGE TOO SMALL"
(4,118 Views)
This allows me to track for circular object for moving object right? Thanks for the help!
(4,118 Views)
Change the resolution of image proportionally  for X and Y, by which you can avoid the Small Image Issue.
(4,107 Views)
-Can you provide your code and sample images?
-What camera are you using and how you are acquiring images?
-What type of images are you receiving?(Color, Gray scale, Binary)
-What function/algorithm you are using to detect circles?
-Often it happens that the image is overwritten or destroyed during the processing and it can throw the error image too small.
uday
(4,086 Views)
