Identify of the specific control of Cluster in event structure.
Maybe, I made design my cluster wrongly to the mixed control in a cluster as seen in attachment.
Due to the mixed type, I can't use "cluster to array" and cannot be identify which is different in a cluster.
In event structure, I need to make a process for change of value in the cluster.
But how can I know if the boolean control is changed or not?
I want to launch a dialog for more input if the Fixed Time is selected.
labmaster.
(3,209 Views)
Accepted by topic author labmaster
You could make a Value Change event specifically just for the boolean inside of the cluster.
(3,201 Views)
