Identify obscure LabVIEW method
For me its Find All Instances, Select Type for polymorphic VIs (I have plenty), and Create Constant/Control/Indicator.
Message 21 of 28
(1,474 Views)
I use "SubVI Node Setup" quite often.
Message 22 of 28
(1,466 Views)
That's because there *is* an "oldest trick in the book."
Madest thou look.
Bill
CLD
(Mid-Level minion.)
Message 23 of 28
(1,462 Views)
@Darren wrote:
altenbach is right, this feature is still available in LabVIEW today. Here it is in LabVIEW 2013:
P.S. - Nobody actually uses this feature. 😛
I used it in the past a few times (LabVIEW 5.x or so) but learned quickly that it was kind of cumbersome. The datalog format changes with every LabVIEW version so that when you upgrade a VI you have to go through upgrading the data log file too in order to use it and my biggest gripes with this functionality was that there was no good interface to actually access the logged data. Yes replaying it in the user interface of the VI was an option save from reading the data in records, but the replay was rather limited in its efficiency when having to look through bigger data and the retrieval could only do sequential access, so that was rather cumbersome. Didn't really help when debugging a function and a simple message logger placed at strategic locations in a VI helped much more and would create a log file that was easily parsable by all kinds of post processing tools including command line grep :-).
I Use Find all Instances also quite regularly together with Properties sometimes. Have stopped setting up SubVI Node setup in here as it makes it rather hard to maintain how a VI appears and where and when it does what it does. Prefer explicit setting of anything UI related in the SubVI itself through Property Nodes, so that there are no hidden configuration settings that you can't see when looking at the diagram alone.
Rolf Kalbermatter  My Blog
Message 24 of 28
(1,429 Views)
At a previous client, some bright C coding types had LabVIEW code with worst case con panes (Ouch)  Very difficult to correctly wire!  Right-Click, un-check View as Icon was pretty handy. When the rest of the developers saw my BD they asked "WHAT IS THAT?!Smiley Surprised"
Me: "Oh, THAT is a VI.  Haven't you ever seen a vi before?"
@ Raven's Fan:  the search term was "Enable Database Access" WITH the quotes.  The link is the top of five returned results.  Of course I tried without quotes first and would never have seen that page so, I thought the link was a good idea.
"Should be" isn't "Is" -Jay
Message 25 of 28
(1,395 Views)
There was a question posted in the past about the types of things to ask during an interview.  One of the questions suggested was to ask how they prefer to see control terminals on the block diagram.  As I icons or not.  It wasn't suggested to not hire those who say to use the icon view, but simply that it was a data point to get to know the persons experience, and coding style.
Seems like this is a complaint about the search function, seeing as google comes up with the right answer.
Message 26 of 28
(1,389 Views)
Typically I search in my local help file, then I use the heading in the NI.com search to provide the online link.  It hasn't failed me yet The local help search and navigation features really do a great job of uncovering some of the more obscure help topics.  Ill keep the google method in mind though.
Message 27 of 28
(1,383 Views)
This has been a fun conversation to watch.
I think though that some kudos are appropriate to the guy who started it...  or maybe extra points for when I take the CLD in a few weeks...
Smiley Very Happy
Dan
Message 28 of 28
(1,373 Views)
