Icon Editor Glyph frustrations
This has only started happening today when I go to edit the icons for my VIs. I click the glyphs tab and go to select a glyph. However, when I click on the glyph (favourite new word) it sends me to another icon editor in which it sends me here. I believe I have an option turned on that causes my clicking of the glyph to not be in it's 'Default' mode. Anybody else run into this problem?
Thanks!
(2,813 Views)
Accepted by topic author cscansin
Its a known issue.  Restart LabVIEW and it should clear up.  If that doesn't work you probably moved the xml and or zip file you used to synchronize glyphs to the icon art library.  put them back where they were and you'll be golden.
"Should be" isn't "Is" -Jay
(2,809 Views)
Ah thank you for the quick reply, the restart worked fine. When in doubt restart.
Cheers!
(2,801 Views)
