Iam unable to read HEX values from xls file
Hi all,
please go through the attachment. The programme will read the data from xls file and everysecond it will be updated. if you observe the DISCRETE column in profile1.xls , it contains FF hex data, but when i run the programme the corresponding A9 will be showning 0 instead of FF , WHY?????/
If i replaced FF with decimal data then corresponding A9( see front panel) will be updated the decimal value.why i couldnt be able to read hex values from xls file.
Thanks in advance
RAJESH
(2,696 Views)
The function "read from spreadsheet file" assumes all fields be formatted as floating point (%f). You should probably read the entire file as raw string then parse it yourself, each column with the appropriate format.
(2,688 Views)
Hi
I have read the whole file as string , but my programme runs slow if i go by the string method.is there any way to
read the hex value from a xls file.
rajesh
(2,668 Views)
