IVI Scope connection problem
Help. What am I missing here? I have 2 GPIB scopes, one LeCroy and one Tektronix. MAX sees them. I believe that I have the correct drivers. It looks like the MAX setup is correct. When I try to connect the error returned is, "IviScope Initialize.viDriver Status: (Hex 0xBFFA1203) The session name or logical name could not be resolved to a session or driver session". Also are there any diagnostic options that provide a bit more detailed look into things?
(3,500 Views)
Hi Ed,
First, make sure that the logical name you use in your application matches the one you created in MAX. The name is case-sensitive.
To check if the IVI Configuration Server is installed properly, highlight the 'IVI Drivers' category in MAX and click on the 'Information' tab at the bottom of the window.
If this doesn't help, contact our Instrument Drivers group at NI directly at instrument.drivers@ni.com and attach your IviConfigurationStore.xml file (C:\Program Files\IVI\Data).
Vesna Jadric
Instrument Drivers/IVI
(3,500 Views)
