IVI ICP for LabView 7.1.1 not available?
I am finally using LabView 7.1.1 (with Matlab R2006a scriptnodes!) effectively, but now I need to control an Agilent E4445A spectrum analyzer.  I downloaded agesa_LV71.msi from the instrument library and attempted to run it, but it gives a dialog box demanding that the NI IVI Compliance Package (ICP) be installed first. The dialog box also gives a URL, but when I go there, I see only the ICP package for LabView 8.x.  I also poked around a bit looking for an ICP for LabView 7.x, but no dice.
If necessary, I will ask our IT folks (who did the installation over the network) to find this stuff (on the installation CDs) and install it, but I would rather do it myself and save some time.
Suggestions?
(2,837 Views)
I think the latest includes support for 8.2 as well as older versions. But, if you want, the entire list of them is available here.
(2,832 Views)
Dennis,
Thanks for tip.  The pages leading to ICP25.exe all talk about it being for 8.x, and even the README page says so at the top.  It's not till
halfway through that there's mention of backward compatibility.  I downloaded ICP25, installed it, and then installed the IVI drivers for the
E4445A with no problems.
Thanks again!
(2,816 Views)
