ITERATIONS WITH MODBUS LIBRARY
I have a problem to solve on my application.
I'm using MODBUS protocol to connect my computer to a inverter driver. The protocol using is not the problem.
I have to insert one value A, 7 secondes after a value B and 6.5 seconds after a value C. All these values to the same Data input on MODBUS block.
I think I don1t have enought knowledge to complete this task because I cannot find a structure or syntax to solve this.
Could anyone helpe me please?
Already grateful, Bruno Ivo.
(3,454 Views)
Greetings, have you taken the basic courses for LabVIEW? This problem sounds like a very simple task for the elapsed time express VI. I can think of at least 4 ways to solve this right off the bat, and I'm certain there must be more. Just think dataflow:
-Insert value A
-Elapsed time VI waits for 7 seconds to pass
-Insert value B
-Elapsed time VI waits for 6.5 seconds to pass
-Insert value C
-End writing and wait for trigger again
You could even split it into 3 SubVIs for educational purposes.
(3,445 Views)
I did indeed.ok,I thought about doing like that.the problem I found (I assume that is ladylike said)is that,themodbus block only accept one wire at its data input.And to insert 3 different values with time delay I have 3 wires on their outputs to connect to my only box. Did I make my self clear? I don't know if you understand what I mean.
(3,434 Views)
What makes it easier is that all the values for now are already defined, like, 9,6... and I just want them to go on my data input of the modbus box with the time delay... but I'm not managing to do that because I get 3 different wires to connect on it. I was thinking if there's a function that updates one value based on some operations... so then I could connect this only box to the modbus box and my problem would be solved
(3,432 Views)
Clear as mud. It would be helpful if you posted your code or a snippet (not a screenshot) of it, so we could better see what you are trying to do. Also why do you need to wait before inputing data?
(3,410 Views)
