ISA Bus Interface
TO WHOM IT MAY CONCERN:
I am using 40+ clocked digital lines from two NI PCI cards that will control my ISA Bus Interface.
How do I design this ISA Bus Interface in the LabVIEW ? I have 16 Address lines and 16 Data lines, and several other lines. Any suggestions ?
(3,582 Views)
I'm curious, what is your overall application/goal of this project?  And what specific NI hardware are you using?
Erik
(3,556 Views)
I am using NI PCI-6541 and NI PCI-6289. I have ISA Bus interface on PCB card, and need to be able to test it (ISA Bus) using these two cards.
(3,545 Views)
Hi Intern,
I believe this issue is the same as your other post, here. Let's continue in the other forum.
Thanks!
David L.
Systems Engineering
(3,532 Views)
