IRIG from LabVIEW
I was wondering if anyone out there had experience reading from a
PCI IRIG card with LabVIEW. Can anyone make a recommendation as to
which vendor's IRIG is reliable and comes with a driver (LabVIEW, dll,
ActiveX) that is reasonably straightforward to use within LabVIEW.
Dave Thomson
David Thomson 303-499-1973 (voice and fax)
Original Code Consulting dthomson@originalcode.com
www.originalcode.com
National Instruments Alliance Program Member
Certified LabVIEW Developer
Certified Instrument Driver Developer
Research Scientist
303-497-3470 (voice)
NOAA Aeronomy Laboratory 303-497-5373 (fax)
Boulder, Colorado dthomson@al.noaa.gov
There are 10 kinds of people: those who understand binary,
and those who don't.
(3,118 Views)
Hi Dave,
I once used a card from Datum that had a LabVIEW driver. It appears that the company is now part of Symmetricom. A card similar to the one I used can be found here. I didn't use it for IRIG output much - mostly used the GPS antenna for an accurate pc clock. I used the cards in some portable systems in Alaska and had no reliability problems.
(3,118 Views)
