09-05-2019 09:32 AM
I am trying to pipe in IRIG and 1 PPS data to my 7972R FlexRio device.
From my understanding (I also made a post about it), to pipe in an external clock, I would use NI-Sync and just set the destination location as shown (attached) (also why cant I set it to the backplane and only PXI_CLK10_IN?). From my research, for IRIG and 1PPS I would need the 6683 since it can decode IRIG and 1PPS.
My question here is how would I pipe data to the FlexRio? I tried using the IO nodes and such to no avail. There doesn't seem to be an option to pipe in data from the backplane to the FlexRio (granted I am a newbie). From other threads, it seems like I need to create a read/write control (https://forums.ni.com/t5/LabVIEW/Transfer-data-between-FlexRIO-7962R-NI-5781-and-PXI-7853R/td-p/3796...) ?
I even tried using user controlled I/O sampling to no avail. It appears that I can only use the internal FLexRIO clock.
Is there any way to pipe my external clock to the flexRIO too?
09-06-2019 05:23 AM
Which, if any, FlexRIO Adapter Module are you using? Is anything connected to the 7972?
09-06-2019 07:11 AM
currently nothing is connected to the 7972 (didn't think it was necessary since I was just using it for proof of concept). I have the 6583 and 6584 modules to use. If I attach those, would is there some option for an external clock/IRIG/1PPS?
