05-31-2010 07:55 PM
Hi.
I'm trying to integrate an IQEye702 camera into an existing inspection application. I'm using the ethernet connector to control the device.
Which will be a better approach TCP or VISA?
Best regards.
Solved! Go to Solution.
06-01-2010 01:53 AM - edited 06-01-2010 01:53 AM
06-01-2010
09:28 AM
- last edited on
07-17-2026
07:22 PM
by
Content Cleaner
You can use TCP/IP or try Vision Acquisition Software, https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html, which currently support IP cameras.
06-08-2010 10:11 PM
Hello rolfk.
Thanks for your reply.
I started with VISA but I have switched to TCP as you have advised. 'Managed to establish communication with the camera, but still struggling with some of the commands, some of them are a bit tricky to send.
Thanks again and best regards.
06-13-2010 10:07 PM
Hello KateB.
I have Vision Acquisition 8.6. Does this support IP cameras?
I will install it today. Keep you updated.
Thanks and best regards.
06-13-2010
10:10 PM
- last edited on
07-17-2026
07:23 PM
by
Content Cleaner
No, it's not.
You must use https://www.ni.com/en/support/downloads/drivers/download.vision-acquisition-software.html
