IP integration node:::VHDL+LAVIEW FPGA
Dear members
 can I use a user defined library or package inside IP integration node???
for example library that contain a function  for fixed point operations???
Like
library IEEE;
use IEEE.STD_LOGIC_1164.ALL;
use mustafa.....pkg
hi ?Q>
(3,323 Views)
Hello mangood,
Yes, you should be able to work with user defined libraries by just calling them in your VHDL code.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,273 Views)
@REDS wrote:
Hello mangood,
thank you
solved
hi ?Q>
(3,249 Views)
ok
i forget to  ask
if i use block memory inside this ip integration node using vhdl
how can i access same block memory by using LABVIEW_FPGA VI ??
like in figure below
i need to use same memory two time first at ip then use it using labview block vi
hi ?Q>
(3,243 Views)
Accepted by topic author mangood
Unfortunately, there is no way currently to directly access a memory block from both LabVIEW FPGA and an IPIN node. You will need to drop a memory read/write node next to your IPIN node and handle the address and data lines from your IPIN node as ports.
(3,206 Views)
