IP IMAGE
Hello everyone
I have an ip camera that outputs a web image via an ip address.
I'm not able to get this image through labview, is there any library or example to help me?
Message 1 of 16
(3,712 Views)
Well, what have you tried?  There's an HTTP GET VI that might work if you can connect to a session with it and know the URL.
Do you need to save the image or just show it?  To show it, you could try just embedding a web browser in your front panel via ActiveX.
Also, what model of camera is it?  Depending on the model, it might have an API in addition to just a web interface, and you might be able to use that.
Message 2 of 16
(3,678 Views)
what's a web image? webP?
can you access your ip camera image via VLC?
Message 3 of 16
(3,660 Views)
+1 for VLC.  Here is some example code I've used on IP based cameras, and USB webcams.
Message 4 of 16
(3,648 Views)
I tried to follow the tips you gave me, but I'm not getting where I want.
There is an application that creates an IP for my cell phone's camera, and through the brownser I can get images from the camera. What my boss asked was that I create a VI that takes this image from the cell phone, through the labview, and I can't do it, these paths you gave me, would it be the best for this?
Message 5 of 16
(3,540 Views)
You still haven't shared anything.  What have you tried?  What about it isn't working?  What errors are you getting?
Message 6 of 16
(3,519 Views)
I don't understand how I'm going to connect the tips you gave with my problem.
I'm new to the platform and I'm having a hard time understanding it. I'm sending a print of the image I need to get in real time.
I need to open a screen in labview that transmits this image from the camera in real time, I don't need to save anything
Message 7 of 16
(3,511 Views)
So you open a browser window to "http://192.168.15.3:4747/video".
You need to use the HTTP Client VIs here. Have you tried a LabIEWHTTPClient.lvlib/GET.vi call with this URL? What error do you get? What doesn't work?
And no this won't give you an image yet. But before we can do that you need to get the data into LabVIEW first. Then we can start to worry about how to get this data formatted in a way that it can be displayed. Also important will be to know if NI IMAQ Vision is an option for you or not. Do you have NI IMAQ Vision available?
Rolf Kalbermatter  My Blog
Message 8 of 16
(3,505 Views)
For someone wanting to use LabVIEW, you've shared a surprisingly low amount of code.
Message 9 of 16
(3,504 Views)
it gives me this information in the "body" and "headers" field and I don't know how to proceed after that
Message 10 of 16
(3,497 Views)
